Page 75 of 76 FirstFirst ... 2565717273747576 LastLast
Results 741 to 750 of 752
  1. #741
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
  2. The Following User Says Thank You to zooguy For This Post:
  3. #742
    Apr 2010
    Troy
  4. The Following User Says Thank You to zooguy For This Post:
  5. #743
    want to go racing at the drag strip ... passenger side rear drag bag in the coil spring got a hole in it ...
    Solution....
    $5 rubber football from Walmart
    Ill let yall know how it goes.
    So hoodrat... but it works. Congrats again man.!
  6. The Following 2 Users Say Thank You to popo8 For This Post:
  7. #744
    Apr 2010
    Troy
    Thank you popo ... i know i do think a little bit different than most and not recommended but they seem to be working for me so far. Im sure my luck will run out some day.
  8. The Following 2 Users Say Thank You to zooguy For This Post:
  9. #745
    Apr 2010
    Troy
    New nitrous bottle
  10. The Following 2 Users Say Thank You to zooguy For This Post:
  11. #746
    Apr 2010
    Troy
    Almost finished converting the car to have two stages of nitrous
  12. The Following User Says Thank You to zooguy For This Post:
  13. #747
    Dec 2011
    Louisiana
    BAD ASS
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
  14. #748
    Nov 2008
    1994 Trans Am
    PA, USA
    Looks good, man.
  15. #749
    Lookin good man. Show off ur new sign!
  16. #750
    Apr 2010
    Troy
    Sorry for the long times between posts. Been busy with work and lots of changes in life .... anyways i got a 8 point cage put in sub frame connectors and a anti-roll bar. received_609250756345413.jpegreceived_325084258458211.jpegreceived_246555496613342.jpegreceived_253342579075466.jpeg
