Fastbird
Page 66 of 67 FirstFirst ... 1656626364656667 LastLast
Results 651 to 660 of 667
  1. #651
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    bethany, ok (okc)
    well I was having problems with my alternator so I finally took her to a shop and had it converted to be a single wire and it works fantastic ... today I took it for my very first test drive out on the roads. I knew it would be smart to stay close to the house in case anything were to happen. So I went about a mile down the road turned got on the highway probably got up to 45 50 miles an hour and I noticed a little bit of steam and then water droplets on my windshield. so I got off at the next exit after approximately one half a mile got off the highway and stopped hopped out to take a look.
    Steam was pouring out around the water pump area. I found out one of the plugs I made had come out partially so thankfully it's an easy fix. I don't believe the motor got too hot. it didn't smell hot.
    So after waiting for about half an hour knowing I had little to no water I drove the rest of the way home which was thankfully less than a half a mile.
    Sent from my SM-N910T using Tapatalk
    94 Formula; sleeper/budget build - total invested so far $2777,
    best pass to date 11.902 @113.73 (forged shortblock coming soon)
    95 Formula, R.I.P (check you oil pump drive gear)
  2. #652
    Apr 2010
    Troy
    bethany, ok (okc)
    Also on my short test drive the transmission got quite hot. I'm running a pretty good size transmission cooler because I have a 4000 stall. Well the transmission got up to around 240 degrees and oddly enough my transmission cooler was completely cold. The car drove pretty good before leaking water out of course. so I'm not sure what's going on with the transmission.
  3. #653
    1994 camaro
    Lehigh Valley PA
    Quote Originally Posted by zooguy View Post
    did you take the plastic plugs out of the trans cooler before putting the lines on??
    2009 G8 GXP #871 - Stock and faster than my LT1
    1994 Z28 T56 - Le2 H/C, SBE, Hooker lt's, some rod ended suspension stuff, and a whole lotta tetanus
    The wrench for LTConvert's 94 Z28- Ellwein 383/LE Trickflows/ P600B/ CPT Pro Race/Pro Torque 3200
  4. #654
    Apr 2010
    Troy
    bethany, ok (okc)
    They were purchased used and there were no caps but thank you I would have noticed that
  5. #655
    Mar 2015
    Stormy
    1995 Trans Am
    Washington
    Thats a good leak there. Take a line off the cooler put it in a bucket and start it up. To see if any fluid is pumping. Just for a bit. Not the return line anyways good luck.
    ... on my tablet using Taptalk
    1995 Trans Am - CAI - TB coolant bypass - Performance Muffler - Poly mounts - stock LT1/A4 - 13.3 1/4 - 1.9 60 foot , driven daily. .
  6. #656
    Apr 2010
    Troy
    bethany, ok (okc)
    Got the water pump properly plugged now time to put water back in and figure out the trans temp issues.
  7. #657
    Apr 2010
    Troy
    bethany, ok (okc)
    Well now I'm going to be working on figuring out my transmission temperature gauge. I replaced the temperature sensor I still have the same problem.
  8. #658
    Mar 2015
    Stormy
    1995 Trans Am
    Washington
    Are the temp sensor and gage matched?
  9. #659
    Apr 2010
    Troy
    bethany, ok (okc)
    Yes
  10. #660
    Mar 2015
    Stormy
    1995 Trans Am
    Washington
    Weird.
