Results 1 to 10 of 19
Thread: stand alone shift lights?
09-11-2008, 06:18 PM #1
is there a shift light i can just buy, and i dont need a tach or anyhting to hook it up? and if so where can i get it? thanks guys
09-11-2008, 06:20 PM #2Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
Raptor shift light, i think summit racing has some of their own now too
09-11-2008, 06:53 PM #3
09-11-2008, 08:00 PM #4
These are the ones that Thunder Racing has. I use them every chance I get. Wonderful sales staff there. I've never had an issue with them, period.
http://thunderracing.com/catalog/?ac...vid=4&pcid=224
Basically, you'll mount the light somewhere and you'll hook up the tach signal. You should be able to do this by tapping into the green wire on your coil connector. I reccommend using the connectors that are made for this purpose specifically. I can't remember what they're called, but you can get them at about any parts store. You can also get your tachometer reference a wire in the PCM, but I don't know which one you'd need to tap. Now that I think of it, I think there's 2 options on the PCM wires.
It should be a pretty simple install, but I can't say for sure as I have never installed one. I would think 3 wires at most. Keep in mind you'll need the proper pills for your desired setting.
09-11-2008, 08:33 PM #5
ok thanks!!! i need to go get this asap lol
09-12-2008, 01:30 AM #6
personaly i like the ones that have the digital rpms built in. I thinks its pretty neat.
1994 Camaro Z/28 Hardtop
Moroso CAI, Pacesetter LT's, !EGR, !AIR, 160* t-stat, 3.73's, MadZ28 Tune.
09-12-2008, 01:38 AM #7N2O Breathing Demented Tuner
- LTx Land...409 of the 90s!
- 583
I absolutly love my new AutoMeter Tube light. I did not realize it had a Tach built in! I can actually read the damn thing going down the track and hit my shift points.
I highly recomend itEllis
Faster Then a LS1!
09-12-2008, 01:39 AM #8
09-12-2008, 08:38 AM #9N2O Breathing Demented Tuner
- 583
09-12-2008, 09:27 AM #10
Raptor
I run them in my own cars and customer cars. They are small and easy to place + just a simple 3 wire hook up. ( no additional tach driver either )
power
ground
tach
+ color options
http://www.speedinc.com/cont.cfm?cid=C0000503Larry @ Speed Inc.
FOR SALE
97 Z/28 SI 396, SI H/I, LE H/R, FLT Level 7 w/ Yank SS3600, S60 w/ spool & 3.73, UMI Suspension, Nitrous Outlet
10.62@126 NA 1.40 60ft
9.67@138.9 200 shot 1.31 60ft
best MPH 140.5
GM High Tech cover car April 2009
www.speedinc.com
