Results 21 to 30 of 35
Thread: Finished my 355 build
02-18-2014, 02:56 PM #21
Stock shortblock with 110k
AI 200cc heads and 228/234 cam
AI CNC'd street/strip intake manifold
Edelbrock 58 tb, KN CAI
Hooker LTs, no-name O/R y-pipe, Borla catback
Made 404/385 through the T56 and 10 bolt with stock 3.42s. My y-pipe has a 2.5" choke point where it plugs into the I-pipe, so I think there are 15-25 numbers left in a better exhaust setup. The current y-pipe is a used one I had lying around and put on the car to get it back on the road a few months back. Intention is to put a better y on it sometime soon and probably do some minor touch up on the tune and see what it makes. It's peaking earlier (around 6100-6200rpm) than I've seen in other cars with this same cam and heads, so that leads me to believe that there's a restriction somewhere. We'll see.
It runs out well on the street and blows street tires away, even from a 50-60mph roll in this cool weather.Cayenne Red Metallic 1997 Z28 M6
Bolt-ons, AI H/C/I, Hooker LTs, chrome ZR1s, etc.
406/385
02-18-2014, 07:40 PM #22
Nice numbers for sure especially if you have an exhaust restriction. The Y-pipe merge is often overlooked I think on these cars. I built my own Y pipe using a flow master merge, the pipes come together in a nice radius and them parallel into the merge. About 18" past the merge I put an E-cutout. On the dyno the cutout was worth 15hp/15ftlbs at peak and more than that in some areas in the lower RPM. I'm not real impressed with the magnaflow cat back as I wasn't expecting that much of a gain from the cutout, I had installed it mostly to be obnoxious.
97 Trans Am M6
355 H/C/I 427rwhp/385 rwtq
1/8th mile 7.39@96.2mph
02-18-2014, 09:17 PM #23
Yeah mine's already obnoxiously loud with the wide-open Borla, but when I swap the Y-pipe I'll also do a cutout just aft of the merge. Ought to be worth something, particularly with the cam profile I'm running. Most of the guys I've talked to running the same basic setup I am are 420-435rwhp, peaking around 6400-6550rpm, with similar torque numbers to what I'm making. They're all running cutouts or true duals with dumps. This is mainly why I think my full catback and pinched y-pipe represents a substantial restriction.
For now though I'm happy to just drive it and enjoy the fact that it's not on jackstands.Cayenne Red Metallic 1997 Z28 M6
406/385
02-18-2014, 09:51 PM #24
Man that is my build almost exactly! Just swap t56 for th400 and add a 150 shot.
Now: m6, 24x conversion, full bolt ons, fullish suspension
In the works: forged 355, le2, th400, 9", direct port 200 shot. Ton of weight reduction!
04-19-2014, 09:30 AM #25
Just wanted to post an update on the car.
Made a few changes:
-4.30 gear
-Weld RT-S wheels to replace my 11 year old ET streets on stock 16" wheels
-27" Hoosier Quick Time Pro Bias Ply and skinnies up front
Took the car to the 1/8th mile drag strip and was finally getting the car to act the way I wanted off the line. I was just getting the launch figured out by slipping the clutch just right and they told me to come back with a roll bar. I'm also afraid I may have put too small of tire on the rear, I'm hitting the 7K rev limiter right at the finish line, maybe a few feet before. A 28" would probably work better.
drag strip 4-18-2014.jpgside.JPGslips 4-18-2014.png97 Trans Am M6
04-19-2014, 10:16 AM #26
Congrats on the new times. Car looks amazing. Keep workin in that 60ft. 28s will help with thay also.
94 trans am forged 355, le 21* trickflows, le cam, a4 3800 stall
04-19-2014, 05:55 PM #27VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
great looking car! love the color, congrats on the times..throw the 28's on and see if it helps at all! you'll have a little bit more sidewall so it'll help a tiny tiny bit and kill a little rpm
04-19-2014, 11:40 PM #28Lurker
- Nov 2013
- David
- 97 355 Green TA
- Deltona, FL
- 303
What style were the rims you had on it before? I actually like those, and it's rare that find rims worth buying for me
97 TA (Rebuilding):Stock bottom end 355, CAI, 52 TB, Ported intake and lt1 heads, 227/235 LE cam, Ultra-Pro-Mags 1.6RR's, Hooker LT's, single flowmaster, McLeod Clutch. Need a 9inch rear to handle the abuse
FLOGROWN
04-20-2014, 05:56 AM #29
That's awesome man. Car looks amazing.
04-20-2014, 10:57 AM #30
Looks good! Get that 28" tire on there, and you'll be fine. How do you like that 24x conversion?
S60 rear
