Page 2 of 28 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 277
  1. #11
    Jul 2013
    1995 Silverado, 1993 Del Sol
    New Orleans, LA
    Jul 2013
    New Orleans, LA
    Jul 2013
    New Orleans, LA
    Here's a quick question... The engine was running strong when pulled but is there anything I should change that is common to fail on these and would be easier to change out while the engine is pulled?
  4. #14
    The FABRICATOR!
    Jul 2011
    southern illinois
    Great question. While its never happened to me, I read a lot about oil pump pickups falling off. Now would be a great time to address that. Summit sells a complete oil pump kit with a high pressure spring installed with the pickup welded on for $50. Or you can just have yours welded and add the high pressure spring.
  5. #15
    Jul 2013
    New Orleans, LA
    Thanks man, That's something Ill def look into doing. Also, the transmission in the car was grabbing perfectly in 1-2 but once in 3rd it would slip with any power being put to it. Does this sound like internal damage or could it be a servo or something not so hard to fix?
  6. #16
    Jul 2013
    New Orleans, LA
    cleaned a little
  7. #17
    Quote Originally Posted by eirik View Post
    Ull need to have a tranny expert check that.
    What trans is in the truck?
    MEMBER @ LTXtech.com
  8. #18
    Founding Member
    Joplin, MO
    Is this a 4L60E? When I did my LT1 swap in my 96, we put another speed sensor in the tranny. You'll need someone who can weld aluminum to put the bung in and they are finicky as the reluctor must within millimeters of the gear.
    Of course this would not explain it slipping, but rather would keep the trans from engaging the gear to begin with without the solenoid working.
    1997 Camaro Z28
    Lots of visual horsepower, full bolt-ons, and a little spray....
    Quote Originally Posted by quik95lt1 View Post
    yea so back to the tune..........do what i said before you make yourself a paperweight lol
  9. #19
    Jul 2013
    New Orleans, LA
    The truck has the 4L60E, the Camaro I'll have to double check bc someone was telling me it was a 700r4.
  10. #20
    If its the proper trans for the 95 CAMARO it should be a 4L60e...
    WHICH trans is slippin...one in truck or car?
