Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 63
    Dec 2011
    JeremY
    1972 NovA
    Elsberry, MO
    Default Widely used acronyms for the LTXTech Forum
    Anybody that would like to add to the list below for acronyms generally used on this forum, please post and I will add to the first post. May help out fellow members new and old.
    2OTL = 2 on the left
    9C1 = Police Package
    A4 = Automatic 4-speed transmission
    AFAIK = As Far As I Know
    A/FR = air/ fuel ratio
    AI = Advanced Induction
    AIR! = Air pump delete
    ALDL = Assembly Line Diagnostic Link (ALDL Cable for use with programming)
    BGM = Bright green metallic
    BLM = Block learn multiplier
    CAGS = Computer aided gear selection (AKA: Skip-shift)
    CAI = Cold air intake
    CR or C/R = Compression Ratio
    CETA = Collector Edition Trans Am (CETA Mod, painting lower rear bumper)
    CTS = Coolant temperature sensor
    DCM = Dark Cherry Metallic
    DD = Daily Driver
    DFCO = Deceleration fuel cut-off
    DGGM = Dark Green Grey Metallic
    DR = Drag radials
    DTC = Diagnostic trouoble code(s)
    EFI = Electronic fuel injection
    EGR! = Exhaust gas recirculation delete
    ET = Elapsed time (drag racing)
    EWP = Electric water pump
    FI = Forced induction
    FMIC = Front mount intercooler
    FML = F*ck my life/luck
    FPR = Fuel pressure regulator
    FRC = Fuel rail cover
    FS = For sale
    FTW = For the win
    FTMFW = For the Mo-fo-in win
    FWIW = For What It's Worth
    GI = Gauging interest
    GLWS = Good luck with sale
    GTFO = Get the Fock out
    H/C = Heads & Cam
    H/C/I = Heads, Cam & Intake
    HR = Hydraulic Roller
    IAC = Idle air control valve (http://shbox.com/1/iac2.jpg)
    IAT = Intake air temperature
    ICM = Ignition control module
    IIRC = If I remember correctly
    IMHO = In my honest opinion
    IMO = In my opinion
    J/K (JK) = Just kidding
    KM = Knock module
    LCA = Lower control arm
    LE = Lloyd Elliott
    LMAO = Laugh my *ss off
    LOL = Laugh out loud
    LT = Long tube headers
    LTCC = LT (engine) coil conversion
    M6 = Manual 6-speed transmission
    MAF = Mass air flow
    MAP = Manifold absolute pressure
    MIDS = Mid-length headers
    MWC = Midwest Chassis
    N/A = Naturally aspirated
    OBD = On-board Diagnostic (OBD-I; OBDII)
    OCC = Olds Custom Cruiser
    OP = Original Poster (original post)
    OTVC = Over the valve cover
    P/A = Power adder (super/turbocharger, nitrous)
    PE Mode = Power enrich mode
    PCM = Powertrain control module
    PCV = Positive crankcase ventilation
    PO = Previous owner
    PP = Pressure plate
    PPM = Purple pearl metallic
    PHB = Panhard bar
    PSN = Playstation Network (User ID)
    PTV = Piston To Valve (Clearance measurement)
    QBM = Quasar blue metallic
    RMS = Roadmaster Sedan
    RMW = Roadmaster Wagon
    RR = Roller Rockers (i.e. 1.6RR, 1.5RR)
    RT = Reaction time(drag racing)
    RWHP = Rear wheel horsepower (REAL wheel....)
    SBC = Small Block Chevy
    SC = Supercharger
    SCR = Static Compression Ratio
    SD = Speed Density
    SFC = Subframe Connectors
    SHORTIES = Short-Tube Headers (block-huggers)
    SMH = Shake my head
    SOM = Sunset orange metallic
    T56 = Manual 6-speed transmission
    TA = Torque arm, OR Trans Am
    TB = Throttle body
    TBB = Throttle body bypass (http://shbox.com/1/tb_bypass.jpg) (http://ltxtech.com/forums/showthread.php?23835-Throttle-Body-Bypass)
    TCC = Torque converter clutch
    TDC = Top dead center
    TNT = Test 'N Tune (Usually an open testing/grudge night for drag racing)
    TPS = Throttle position sensor
    TT2 = Torque Thrust 2 (wheels)
    TTIWWP (TTIWWOP) = This thread is worthless with pics (ADD SOME PICS!)
    TTT = To the top, OR Thread to top (Used to bump a thread up on the list)
    VATS = Vehicle anti-theft system
    VC = Valve cover(s)
    UCA = Upper control arm
    VE = Volumetric efficiency
    WOT = Wide open throttle
    WTB = Want to buy
    WTS = Want to sell
    WTT = Want to trade
    WX3 = Impala SS Package for Caprice
    XBL = Xbox Live
    xBx = xBrandonx
    '72 Nova "HadeSS"
  2. The Following 6 Users Say Thank You to JCzNova For This Post:
  3. #2
    LTX AUTOX GURU!
    Oct 2010
    Manhattan, KS
    xbx=xbrandonx
    To soon?
    94 Trans am. Built 383/T56(437/409) Wilwoods, tubular suspension, QA1/BMR, Watts Link. Stripped down and set to kill!
  4. The Following User Says Thank You to MeanTA For This Post:
  5. #3
    Aug 2009
    Kyle
    '95 Trans Am
    Elizabethtown, Kentucky
    Lol
    Sent from my SAMSUNG-SGH-I547 using Tapatalk 4 Beta
    Kyle
  6. #4
    Dec 2011
    JeremY
    1972 NovA
    Elsberry, MO
    Quote Originally Posted by MeanTA View Post
    xbx=xbrandonx
    To soon?
    Not for me. People need to know what it means, lol.
    '72 Nova "HadeSS"
  7. The Following 2 Users Say Thank You to JCzNova For This Post:
  8. #5
    Overworked/Underpaid
    Aug 2012
    Peter Alpiger
    1996 Trans Am WS6; 1994 Corvette [GS Clone]
    Carrollton, Texas
    2OTL = 2 On The Left
    LTs = longtubes
    DRs = drag radials
    PHB = pan hard bar
    Sent from my SGH-i777 using Xparent Red Tapatalk 2
  9. The Following 3 Users Say Thank You to Blackbird96WS6 For This Post:
  10. #6
    Founding Member
    Jay
    93 Ultra Z
    Delaware
    Pos = jay's 93 ultra z
    SMH = shake my head
    FML = EFF my luck
    Sent from my DROID RAZR HD using Tapatalk 2
  11. #7
    Ive always wanted to know what 2otl was
    Co-Owner/Admin @ LTXtech.com
  12. The Following User Says Thank You to popo8 For This Post:
  13. #8
    Stickied!!!
  14. The Following User Says Thank You to popo8 For This Post:
  15. #9
    Founding Member
    Jay
    93 Ultra Z
    Delaware
    POPO8 = ltx master post whore.
  16. The Following 4 Users Say Thank You to jaysz2893 For This Post:
  17. #10
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    FFRED - Fastbirds Fucking Ridiculous Economical Disaster
  18. The Following User Says Thank You to Fastbird For This Post:
