Results 11 to 20 of 85
06-04-2013, 06:45 PM #11VIP Member
- Nov 2010
- CHRIS
- 94 CAMARO.
- Biloxi, MS
- 1,342
imo i would look for a 6 speed vet. they have better a setup for speed. your going to need north of 1k to run the number. but the biggest thing is getting the combo to make big power below peak hp. when you shift at that speed the engine needs to make enough power to pull it back up. turbo would probably be the best choice. also you want the last gear change close to minimize rpm drop.
4.1 rear gear. 7k shift point. .8 5th gear and a .63 6th gear. if you shift at 7k it will drop back to 5500 rpm. at 7k in 6th it will do about 207.
06-04-2013, 07:09 PM #12Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
FWIW, my old vette with a 3.42 rear went 202 at Texas last year, with about 875 to the wheels. But Vette's are so much lighter and aerodynamic than F-cars.
06-04-2013, 07:33 PM #13
I have been reading up on the lmr car. It hit 239mph at 15 pounds of boost. Making 1300 fwh.
On paper it looks possible with the LT1. Just got to make the power and be able to spin that high for that long without letting go.
Plus side i can get access to K-States wind tunnel(friend is head engineer of department). Where they can push the wind speeds. So i can test if needed. lol94 Trans am. Built 383/T56(437/409) Wilwoods, tubular suspension, QA1/BMR, Watts Link. Stripped down and set to kill!
06-04-2013, 07:39 PM #14
From what im finding the LT1 drag coefficient is .08 higher then the C5
06-04-2013, 07:54 PM #15The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Is your car a hardtop or t top?
06-04-2013, 07:55 PM #16
06-04-2013, 08:01 PM #17The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
I think you could find some aerodynamic tricks to do to the body to help it out. Wind tunnel testing will be a big plus to see what helps.
06-04-2013, 08:27 PM #18"The Rock"
06-04-2013, 08:32 PM #19
200 mph is a pretty tall order .......C6z's are barely getting 180. Maybe run it once and see what your car will do then go from there. Id be interested to see what it does
Bryan
1994 B4C "Special Service" Camaro - Stock LT1 - 6 speed - 46k miles - Madz28 Tune - 307/340 sae
LT4 Clutch - Delteq Ignition - K&N CAI - Pacesetter LT Headers - Magnaflow Exhaust - Unbalanced Engineering/Koni Suspension
LS1 Brakes/Drive Shaft - T2R Diff - 373's - much more...
06-04-2013, 09:11 PM #20
Red duct tape cause it makes you faster.
C6 has a higher drag coefficient then the C5. The way i see it. If 4th gems with LS/gen1/Big blocks are doing it. Why not a LT1
I honestly thank it is possible. The race game has been changing. And the 1/2 mile and standing mile is getting bigger. And its something i thank we are missing out on. Because we focus on the 1/4. And no one is really paying attention to this sport in our community.94 Trans am. Built 383/T56(437/409) Wilwoods, tubular suspension, QA1/BMR, Watts Link. Stripped down and set to kill!
The Following User Says Thank You to MeanTA For This Post:
