Results 1 to 5 of 5
05-15-2013, 04:44 PM #1LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Some information about 5 pinion planetaries
I get asked quite often why we don't use 5 pinion 4L65E planetaries. Actually there are a few reasons that I will try to explain. The largest percentage of the time that a planetary fails is because the needle bearing set under the sun gear fails first. When that bearing fails, it sheds needles through the pinions, causing it to self destruct. Both 4 and 5 pinion planets use the same style bearing. I've never seen a 4 pinion planetary fail in a way that a 5 pinion wouldn't have failed the same way. Now, we add in the other factor. 5 pinion planetaries are much heavier than 4 pinions. This is rotationg weight. The more weight you have to spin, the more horsepower it takes to turn something. It may not be dramatic, but a few extra horsepower is a few extra horsepower. The other thing in cost. A REAL GM 5 pinion rear planetary costs upwards of $400. Many shops will advertise "5 pinion planetaries". The first question should always be, "Are they REAL GM planetaries". There are companies making cheap knock offs that I've seen fail is as little as 300 miles. I've seen the pinion exles fall out, and the housings themselves shatter.
So, in a nutshell, a 5 pinion offers little, if any strength improvement, they cost a couple horsepower, they're heavier, and unless they're REAL GM planetaries, they're actually weaker. CPT does however offer 5 pinion REAL GM planetaries as an option if the customer is dead set on them.
FrankGail C. Cahall
05-15-2013, 05:12 PM #2LTX Shootout Coordinator
- 1994 Z28 SATIN BLACK
- Wichita, Kansas, United States
- 177
Frank i am really liking the advice you are giving keep it up
A4, BOLT ONS, TIMMY BUILT TRANS, 4000 STALL S60 410 GEARS,STREET STOCK ALL THE WAY ,AUTO MOITION TUNE, FULL INTEIRIOR, AC,A REAL DAILY DRIVER 12.58 1.65 60FT 108.78 MPH @ 2500FT DA
05-15-2013, 05:12 PM #3Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
Good info as always Frank!
05-15-2013, 08:39 PM #4The Wrench
- May 2009
- Chile
- 1994 9C1 6SPD
- South Jersey
- 1,942
Made this a stickie. Very good info Frank. A good way to eduacate our fellow members.
ASE L1 Master Certified Tech's 9C1 T56. Yeah she's got a big butt. But watch her move it.
R.I.P. Z8
01-05-2014, 12:02 AM #5InActive Member
- Nov 2013
- 1997 K1500, SS/SB
- Kansas
- 199
