Results 21 to 30 of 516
Thread: '94 firebird formula
05-12-2013, 08:29 AM #21"The Rock"
Guess that means u made ur mind up. (if not, copy and past ur issue in the proper are so people see it as a
"help" thread.
Larry (Popo8) Co-owner
LTXtech.com
05-12-2013, 10:19 AM #22Xtreme Member
- Sep 2012
- Chris P. Bacon
- 1994 Firebird Formula
- Lansing MI
- 1,467
after talking with some friends i think i'm going to pull the LT1 and sell it, a friend will sell me a carbed 355 for $500 and i can throw that in so i at least have something fun to drive all summer and save till winter and do the 5.3 or 6.0 swap. i feel like at this point even fixing it is just going to prolong the pain and i'll just end up getting towed again.
'94 Formula 6spd
05-12-2013, 10:36 AM #23LTx Guru
The problem with the Opti is the high voltage section. Take the high voltage out of the Opti, and you have a killer cam position sensor. Add the Bailey Engineering LTCC and your Opti high voltage problems are gone. And you have a nice direct fire ignition using 8 LSx coils.
05-12-2013, 10:37 AM #2410 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
Sucks to hear but I think all of us understand how frustrating these cars can be. People like me are just to stubborn to throw money in another direction!
Injuneer just beat me to it, I was gonna suggest switching to another ignition that may be more friendly to your plans with the car.-Josh
co-owner of BDBRacing.com
NMCA OC 9004
The Following User Says Thank You to 96LT1355Z28 For This Post:
05-12-2013, 11:17 AM #25Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
I thought about doing that, but it seems like rather than swap to LS coils I can spend not much more and buy the whole LQ.
'94 Formula 6spd
05-12-2013, 11:28 AM #2610 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
That's going to involve a PCM/wiring change (which can be picked up with a complete engine), motor mount and bell housing conversion, and I'm not sure if the LS PCM can controll the LT style cluster. Don't get me wrong it can and has been done and I'm sure you already know it's more than just a Saturday swap!
-Josh
NMCA OC 9004
05-13-2013, 06:39 AM #27Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
I might just have a custom harness made because I only need the running motor, I don't need or want any of the wiring for the dash stuff (other than gauges), I just need the motor to run really.
I would really like to get a tubular k-member when I do the swap to save some weight, but that's $$ so we'll see. Yeah I know it's not just a quick swap, but in the long run its worth it to me to deal with one big headache now rather than many as it keeps leaving me stranded.
'94 Formula 6spd
05-14-2013, 02:27 PM #28Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
looks like my fuel pump crapped out. tried starting it and the pump isn't priming. i don't know if this caused the no start or just happens to be happening at the same time. i planned to upgrade it anyway before i sprayed it and the 355 will have a mechanical pump so i guess that's not too big of a deal.
'94 Formula 6spd
05-14-2013, 03:20 PM #29"The Rock"
or...u figure u found this prob to save u the headache of the swap...just in time. Fix it...and hope it works...
LTXtech.com
05-14-2013, 03:50 PM #30"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
Unless he's having a custom bellhousing made, it's more than just a bellhousing conversion. LS transmission input shafts are longer than LT/SBC input shafts. At a minimum it would require a new input shaft and front cover. LS t56's are hydraulic throwout bearing as well (vs our pull fork style), so you're looking at a new slave and clutch set.
