Page 47 of 52 FirstFirst ... 37434445464748495051 ... LastLast
Results 461 to 470 of 516
  1. #461
    Sep 2012
    Chris P. Bacon
    1994 Firebird Formula
    Lansing MI
    First part for this winters project has been acquired
    '94 Formula 6spd
  2. The Following 2 Users Say Thank You to Formula218 For This Post:
  3. #462
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Grabbed a driveshaft off FB Marketplace too, 3” aluminum. Previously went 9.90s so it should be plenty for my 13s lol
    Quick Performance F9 has been ordered with a Yukon center, can’t wait to have 4.10s instead of 2.73s lol
    '94 Formula 6spd
  4. #463
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Early Christmas for the bird!
    '94 Formula 6spd
  5. #464
    Mar 2015
    Mike Storm "Stormy"
    1995 Trans Am
    Washington
    Blog Entries
    1
    Nice!
  6. #465
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    moore, ok (south okc)
    Quote Originally Posted by Formula218 View Post
    Nice what did that cost?
    Sent from my SM-N910T using Tapatalk
  7. #466
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Quote Originally Posted by zooguy View Post
    $1950 with the 10% off for their black friday deal. With the 3" driveshaft and Trutrac i've got $2600 into the 9" swap. Ive tried to find a list of all parts needed but I haven't found a definitive list of everything needed. This is what I bought http://www.quickperformance.com/QP-G...xles_p_55.html . The only special options i got was the fabricated big web, and lightened axle flanges. Here is by order:
    I think it should work with my founders LCAs. I have a feeling I might need to get an adjustable panhard bar it center it. My 10-bolt sat perfect with my drop so the one I have now is a Founders non adjustable. They say it will work with a stock torque arm but i might grab a tubular before spring anyway. Anyone see anything that I will probably need to get before the install.
    '94 Formula 6spd
  8. #467
    Spool? Are u done doing autocross stuff, or am i thinkin of someone else?
  9. #468
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Spool was free with the rear end kit and will be sold, I have the trutrac pictured on the last page that will be swapped in. I got the Eaton for $400 so it didn't make much sense to pay Quick $750 for one too.
    '94 Formula 6spd
  10. #469
    Sep 2012
    Chris P. Bacon
    Lansing MI
    But also yes, I probably am done with auto-X for the most part. I just don't find it as fun as drag/street racing.
    '94 Formula 6spd
  11. The Following User Says Thank You to Formula218 For This Post:
  12. #470
    Sep 2012
    Chris P. Bacon
    Lansing MI
    It's been a quiet summer for the shitbird I've been throwing parts at what I think is an electrical issue. I took the car to work one day and out of nowhere it started to completely lose power for a split second. The gauges would all drop to zero and it would buck like it lost all power for a split second. Ended up making it to work but as I pulled into the parking lot the car just shut off. It would crank but not fire, and the pump was not making any priming sounds. I had it towed home and rewired the fuel pump with an aftermarket relay and all new (bigger) wiring. It fired right up but died again on the test drive I got it back home and tried bypassing the fuel pump trigger wire to see if that was the cause, still doing it. I've also replaced the crank angle sensor, plugs, and wires but still nothing.
    The wiring in my car has always been a nightmare so i've finally bit the bullet and bought a new swap harness from BP-Automotive last week so HOPEFULLY that fixes the issue, but at this point i'm not to confident. The SES light flickers on for a split second randomly while driving but the car is not giving me any codes to work with so i'm just throwing money at it at this point.
    '94 Formula 6spd
