Results 11 to 19 of 19
Thread: Waterpump hosebarb
02-05-2013, 08:56 PM #11
I couldn't find any freeze plugs and then I was checking the barb against a 3/8 thread and the thread looked to small compared to the barb. So I just got some jb weld and put it back on and I'll see what happens. It says its good to 550 degrees.
Sent from my EVO using Tapatalk 2Last edited by ginoz28; 02-05-2013 at 08:59 PM.
94 Z28 TURBO BUILD in progress
02-05-2013, 09:05 PM #12The Wrench
- May 2009
- Chile
- 1994 9C1 6SPD
- South Jersey
- 1,942
There is a difference between regular nut/bolt 3/8 thread and NPT 3/8 thread.
ASE L1 Master Certified Tech's 9C1 T56. Yeah she's got a big butt. But watch her move it.
R.I.P. Z8
The Following User Says Thank You to chile For This Post:
02-05-2013, 09:33 PM #13
Big mistake on the JB Weld. It will eventually fail. The cooling system is under 18psi of pressure.
NPT stands for National Pipe Taper. The threads are tapered for sealing pipe threads. They are not the same as standard nut/bolt threads and the two are not interchangeable.-Joe-
95 T/A.
Advanced Induction 383 - 10.81 @ 124.16, 1.43 60' Video of 10-second pass - 455whp/445wtq
02-06-2013, 12:04 AM #14
02-06-2013, 12:42 AM #15
Clarify here. You said "when I put it next to the 3/8 plug", what are you talking about?
A 3/8" NPT pipe tap is .675" in diameter while a 3/8" standard tap is .375". You need the pipe tap (assuming the 3/8" pipe tap is the correct size).
When you talk about NPT pipe threads the designated thread pitch has absolutely NOTHING to do with the actual size of the pipe/fitting.-Joe-
95 T/A.
02-06-2013, 12:58 PM #16
What I'm saying is it would have fit like this with the bottom of the thread not touching the walls and not sealing anything. And if you bottom out the tap,your just straightening the walls and it won't have the taper to be able to seal tight.
Sent from my EVO using Tapatalk 2Last edited by ginoz28; 02-06-2013 at 01:09 PM.
02-06-2013, 03:36 PM #17
For you to tap the hole for NPT threads you would have to measure the OD of the current hole, then determine what size the closest appropriate NPT threads would be (drilling and enlarging if need be).
-Joe-
95 T/A.
The Following User Says Thank You to RamAir95TA For This Post:
02-06-2013, 04:45 PM #18VIP Member
- Nov 2010
- CHRIS
- 94 CAMARO.
- Biloxi, MS
- 1,342
The Following User Says Thank You to BIG CAT For This Post:
02-06-2013, 05:12 PM #19
Now I'll know what to do when I have it out of the car, I'll drill and tap the inlet and outlet for 1/2 plug.
Thanks for the info guy's
Sent from my EVO using Tapatalk 2Last edited by ginoz28; 02-06-2013 at 06:54 PM.
