Results 1 to 7 of 7
01-06-2013, 06:18 PM #1
Couple of rearend and driveshaft questions.
I have a 93 z28 with stock driveshaft and rearend. (2.73s)
I am picking up a 95 z28 rearend (3.42s)
Also getting a 3 rivers stock aluminum.
Will the driveshaft bolt right up? He has a m6 I'm a4.
Anything I should do to the rear before putting it back in?1993 Z28 Camaro M6 - 355, LE 226/232 .576/.571 110, Full bolt-ons, 17x11 10 spokes , 347rwhp, 367rwtq.
1999 Z28 Camaro M6 - Full bolt-ons - SOLD :sad:
2008 Ford Fusion SE - DD
01-06-2013, 06:49 PM #2InActive Member
- Jan 2012
- 1997 z28 383 stroker
- oklahoma city,ok
- 2,859
The DS should bolt right up
SMOKE TIRES NOT DRUGS
01-06-2013, 07:03 PM #3
lie said driveshaft will fit. As far as rear. i would change the gear oil while your under there.
94 Trans am. Built 383/T56(437/409) Wilwoods, tubular suspension, QA1/BMR, Watts Link. Stripped down and set to kill!
01-06-2013, 07:07 PM #4
Lie said driveshaft will fit?? You lost me.
I'll do fluid and outer axle bearings at least.
He has t56 I'm 700r41993 Z28 Camaro M6 - 355, LE 226/232 .576/.571 110, Full bolt-ons, 17x11 10 spokes , 347rwhp, 367rwtq.
01-06-2013, 07:15 PM #5Originally Posted by mcalus:27095294 Trans am. Built 383/T56(437/409) Wilwoods, tubular suspension, QA1/BMR, Watts Link. Stripped down and set to kill!
The Following User Says Thank You to MeanTA For This Post:
01-07-2013, 02:48 AM #6Banned
- Dec 2012
- 95 Corvette 6spd, 93 Z28, 93 Z28, and 97 V6 soon to be V8 swapped.
- Murphy, NC
- 4,890
You'll need to do something with your speedo gear or you'll be way off.
http://www.transmissioncenter.net/sp...n_______va.htm
01-07-2013, 03:43 AM #7
How do these work in compare?
http://www.dakotadigital.com/index.c...rod/prd126.htm1993 Z28 Camaro M6 - 355, LE 226/232 .576/.571 110, Full bolt-ons, 17x11 10 spokes , 347rwhp, 367rwtq.
