+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: seven not stock
    In the car in frount of you!!
    seven not stock
    88 turbo 2 95 lt1 t-56 set up and here are some pics
    Ever thing that was done to the car
    Motor
    95 lt1 T-56 swap
    modds
    granny speed shop kit
    CC 306
    CC valve 918 spring
    1.6 rocker
    58MM TB
    Accel 30lbs injector
    accel 8mm wires
    NGK plug
    Walbro 255 Fuel Pump
    headers
    MSD cap & rotor
    MSD coil
    PCM for less tune
    cold air intake
    K&N filter
    LT-4 SCM
    2 1/2in exhaust
    X- pipe muffler
    fart cans
    OBD2 set up
    4-core alum radiator
    newer Turbo 2 rear end
    new GM alternator
    new battery
    drilled F-R rotors
    hawk pads
    tanabe front sway bar
    tanabe GF210 springs
    KYB 8 way shocks
    F & R strut bars
    SEVEN NOT STOCK
    here are some pics of a buddy new car he did. The car should run in to the low 10 to high 9 sec 1/4. The motor came out of his jeep JX that ran a 11.8 in the 1/4 with a 150 shot and the jeep weight in at 4500 ++ it was set up for off road and He had 6in lift and 31intires on it at the time . But now its in car car that weight in at 2700 and he is running the 200 shot but the forged 383 that it is can take a 300 shot all day long.
    here is a video of the jeep
    http://videos.streetfire.net/video/F...Ran_132254.htm
    __________________
    SEVEN NOT STOCK
    Is it just the left muffler that is in use``? Just thought about that in the end of the vid :P
    Nice swap, sounds good
    Kristoffer
    1995 Formula M6 - LPE211/219 - GMMG - Full suspension - Full boltons
    no its a true dual
    SEVEN NOT STOCK
    How much do those cars weigh full weight?
    1997 camaro z28- Cold air Intake, 373s, Eibach Pro kit, Flowmaster Exhaust, summit cutout, NX 100 shot, BMR adj TA, ss3600 on the way
    under 3000. Mine weight in at like 2890 with the swap. The turbo 2 weight the most out of the FC.
    SEVEN NOT STOCK
    Damn, that's bad ass. I bet those cars haul major ass.
    -Randall-
    1997 Camaro SS: Pacesetters | ORY | PCM Tune | EGR Delete | LoudMouth I | CME | TTII's
    shasam!! got any more vids?
  9. #9
    I bet your not far off a 11 second pass, what was your best time?
    Looks to be a fun project/toy.
    -Eric
    1997 Camaro SS # 2703
    1999 Silverado
    Z71
  10. #10
    Damn that is pretty sweet!
    -Russ-
    2000 Firebird:
    Trans Am Conversion| VFN WS6 Hood | Loudmouth I | Corsa Clones | Chrome ZR1's
+ Reply to Thread
