Results 1 to 4 of 4
    Dec 2012
    1995 Z28 Camaro
    New Carlisle Indiana
    Default 383 lt1 stroker for sale
    383 lt1 Stroker for a steal!!!
    I have a 383 lt1 short block with piston rings set up for nitrous. It has been bored .30 over cleaned and decked. Parts include:
    Actual Engine CID:383
    Bore (in):4.030 in.
    Bore (mm):102.362mm
    Engine Stroke (in):3.750 in.
    Piston rings: sealed power rings.
    Piston and Ring Oversize (in):0.030 in.
    Piston Material: Keith Black hypereutectic forged aluminum
    Piston Style:Flat top, with two valve reliefs
    Piston Head Volume (cc):+5.00cc
    Wrist Pin Style:Floating
    Piston Ring Facing material: plasmamoly
    Crankshaft Material:Cast steel
    Rear Main Seal Style:1-piece 2 bolt mains
    Connecting Rod Material:Forged 5140 steel
    Connecting Rod Beam Style: Forged I-beam
    Has a comp cams 280xfi cam. Good mid- high rpm range. Duration @ .050 230/236 lift .576/.571
    It also has a Cloyes true roller heavy duty timing cover comp cams cam lock, and I have timing cover. Also have a race serpentine harmonic balancer. $2000 firm. Buyer responsible for pickup or delivery. Call or text Rusty for pictures having hard time uploading them. (574)-520-2227
    Have all receipts for stroker kit, cam, harmonic balancer, timing chain and all machine work done professionally by Kaley Motor Service here in South Bend Indiana.
    Selling it be because I'm going a different route (carb'd 400 small block) for my Z28
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    1994 Firebird Formula
    moore, ok (south okc)
    didnt you have this thread posted already?
    Apr 2010
    Troy
    http://ltxtech.com/forums/showthread...1-383-lt1-2000 ... please dont make multi posts like this. it just wastes space
  4. The Following User Says Thank You to zooguy For This Post:
  5. #4
    Dec 2012
    1995 Z28 Camaro
    I posted it here in regional discussion because different people look at different forums. I never received an email or a text requesting pictures from you man. So i don't know why your trying to tell me what I can and can't do on different forums.
