Results 21 to 30 of 118
Thread: Should I buy a C4 Corvette?
12-26-2012, 11:30 PM #21"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
You do not have to change to a push style clutch. The reason you get the rattling noise, is because the easiest solution is to switch to a single mass flywheel, which takes away the dampening effect the DM flywheel gave (and why it was used), which then causes the trans to rattle at idle due to the gear teeth being straight cut, has nothing to do with the clutch itself.
The Following User Says Thank You to 94Blackbird For This Post:
12-27-2012, 12:08 AM #22
All great info, glad to hear the ZF6 cars have Dana44's. I also heard about the blue and black tag transmissions, good info there as well. But I wonder if my Ram HD clutch from the T56 could be used, I read somewhere you have to have it milled down but it could work. It's grabby down low, but holds very nicely with a reasonable pedal.
I live near El Paso, TX, but thanks for the offer! I'm testing driving a C4 tomorrow that's in my price range, got some decent mods, but it's not the color or interior I prefer. The one I really like is in California, but if I don't fix overdrive in the truck I won't be towing that home anytime soon, I've spent all day screwing with it, now I'm down to the OD solenoid or a seal that pushed out.1994 Z28 383ci - Jake's 4L80 - Moser 9" [LE2 heads and LE cam - 121mph @5500DA]
12-27-2012, 12:15 AM #23"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
What a lot of guys do, is they take a stock LT1 f body flywheel and have it milled 90 thousands because of clearancing issues caused by an unmolested unit. The only changes to the pressure plate you would need to make are to get the correct throw out bearing. Corvettes and F bodies have different bearings, but other wise, from what I've seen of other guys conversions, everything else should bolt right up and be good to go. I've also heard of guys getting stock 4+3 flywheels and having those bolt right in with no modification required.
12-27-2012, 12:26 AM #24
Hmm, what about my Hays billet flywheel? I guess I'll get into that more once I get one...
12-27-2012, 12:32 AM #25"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
12-27-2012, 02:16 AM #26
I'd be using it on the same motor I already have. The motor from the 95 is set to go into the upcoming Vette, then the Camaro gets the Vette's stock motor and then sold.
12-27-2012, 09:06 AM #27"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
You would either have to have the flywheel shaved 90 thou or clearence the clutch fork (it rubs with stock camaro flywheel and clutch disc. Have heard that running a stock corvette clutch disc will alleviate the rubbing) or there is another clutch fork pivot that is supposedly out there that will swap in and get the fork away from the PP.
12-27-2012, 09:06 PM #28
I drove my first C4 today. It wasn't exactly what I was looking for, but I needed to 'break the seal' and drive one before continuing my search. Long story short, I'm sold on them.
The car wraps around you but you can still view everything you need to. You guys talked about fitting three pedals down there. We'll it looked tight, but I never noticed it being cramped or a distraction while driving around. The ZF6 is much nicer to drive than the T56 in my opinion. The thing basically finds 3rd on it's own and is buttery smooth, everything I'd expect from a Corvette. The handling was far better than my 95 Camaro with a PHB/LCA/32mm sway. It almost begged to take turns at lose your license speed. I liked the interior and the way things were organized. The parking brake was weird, the way it retracts back down, but it makes sense. Even with a factory LT1 the car felt zippy. That combined with the weight and smaller size compared to a Fbody made it seem quick and responsive. I can only imagine what it'll be like with a 450hp LT1 up front. So I've got one picked out and tomorrow I'm going to make a final decision on it. I'll post up what happens.1994 Z28 383ci - Jake's 4L80 - Moser 9" [LE2 heads and LE cam - 121mph @5500DA]
12-27-2012, 09:10 PM #29"The Rock"
12-27-2012, 09:11 PM #30"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
