Results 11 to 20 of 21
Thread: 4/7 Swap
  1. #11
    Ok, I found it, I had to do some digging:
    There are a few theories as to why this works out but they are hard to prove exactly. On extreme-rpm small blocks, altering the firing order tends to produce a little more power way up high. People claim that it is because of the cylinder scavenging is different. On a regular firing order you have 1-8-4-3-6-5-7-2. Notice how 5 and 7 are right next to each other. They claim that cylinder 5 robs some of the intake charge from cylinder 7 and that is why moving those firing cylinders away picks up some power. I say that's crap because when you alter the firing order to the 4/7 swap it becomes 1-8-7-3-6-5-4-2. Now you have 4 and 2 right next to each other so technically 4 should be robbing from 2, yet the car picks up power?
    The best theory that I have heard comes straight from the GM LSx design team. There were groups of engineers working on different aspects of the motor. There were teams working on the intake, the crankshaft, and valvetrain. The valvetrain and intake guys said that the firing order was dictated by the crankshaft guys. On the traditional firing order they measured the bearing load on the main caps (1 through 5). Then they took an average. Main #2 was lower and main #4 was higher than the average. By moving the firing order they incresed the bearing load on #2 and decreased the load on #4 bringing both closer to the middle. Basically they smoothed out the load accross the entire crank ie: lowered the deflection. Anytime you smooth out a motor or bring it into balance better it will pick up power. The 4/7 swap gets you closer to this balance.
    I have never heard of a negative thing assiciated with the 4/7 swap. I have heard of guys swapping and not picking up power, but i've never heard of anyone losing power. BTW, motors with the 4/7 swap sound incredible!
  2. The Following 2 Users Say Thank You to joelster For This Post:
  3. #12
    Aug 2012
    1968 SS Camaro 396LT1
    NW AR
    Quote Originally Posted by 94Blackbird View Post
    Granted it moves the adjacent cylinder firing to the 4-2, but think about this. cylinders 4 and 2 are closer to the water pump and the incoming coolant. This swap could be a way to control temperature spikes in the left rear cylinders and equalize the combustion temps across the engine by moving the adjacent firing cylinders in the sequence closer to the incoming coolant and spacing the firing of the rearward cylinders out so as to keep temps down.
    I am sure that there are other ways to accomplish this, but, that could be a natural outcome of the swap aside from changing the exhaust pulses and engine harmonics
    If you are truly worried about cooling run an external pump and put AN lines to the middle of the heads like the pros.
    68 Mechanical Alcohol Injected LT1.
  4. #13
    The way I see it, if there is the possibility of picking up some ponies, it's a win. Like I said, the gains are small, but every little bit counts. Harmonics count for a lot (if this is really where we are picking up the extra ponies), especially when you are counting for longevity (hence one of the reasons for balancing the internals, right?).
    Quote Originally Posted by noice View Post
    Unlike a 4/7 swap, this costs money (machining/parts). A 4/7 swap, if planned for during a build, is a zero cost option (you'd probably be getting a custom cam anyway ... all else is moot). I'm not suggesting the 4/7 swap would have anything to do with cooling, it's just your suggestion costs money (nothing wrong with your suggestion, either, I might add )
    I am not seeing the down side to this. And if what joelster said is right, the added bennies of sound is a good one. It's one of the reasons why I love the BBC is because of loping sound it makes (besides the low end torque) ... very distinct. If nothing else, the discussion here adds to forum and gets people thinking
    94 Z28 LT1 M6 - ​SOLD
  5. #14
    There's a few things you have to change to do the swap. Obviously the camshaft is the biggie. Then you have to re-wire the 2 injectors if you want to. Notice that you don't have to do this. 2 cylinders can fire in batch mode while the rest will be in sequential mode. I don't recommend that, but i'd bet you'd never notice the difference. Then you have to swap the wires on the opti, and it's quite cramped up front.
    The one downfall for doing this and running a stock-type pcm is this:
    If you run in closed loop and 1 side sees a lean spike it will dump fuel to that bank, but in reality it will be dumping into 3 cylinders on that bank, and 1 cylinder on the opposite bank. With an aftermarket pcm you can change the firing order in the box itself.
  6. #15
    Dec 2012
    '96 Z28
    cc MA
    I've always been told this swap is for harmonics & mains and that you wont gain any power from better scavenging unless you pair it with headers to match(tri-y's). T? F? what about equal length headers in conjunction w/ the swap? how would they work out?
    -Dusty '96 Z28
  7. #16
    Quote Originally Posted by joelster View Post
    ... The one downfall for doing this and running a stock-type pcm is this:
    Definitely something I hadn't thought about, but seems plausable.
  8. #17
    Quote Originally Posted by z_speedfreak View Post
    I understood (as stated in my OP), with no other changes, the 4/7 would net about 6-8hp on a SBC. This came from one of the car rags ... er ... mags, back 10-15 years ago. Back then it wasn't near as feasable to do the swap as custom cams were not as easy (or cheap) to come by. I believe you can order cams off the shelf with the swap already built into them now, but don't know this for sure.
  9. #18
    Reher-Morrison were the first guys to experiment with altered firing orders. They built tons of Pro-Stock engines back in the 80's. The gains are small, but they are GAINS.
  10. #19
    Sep 2014
    Joel
    Colorado
    The 4/7 swap looks like it could increase longevity of high horsepower engine by improving harmonics and balance. With that being said the way. The SFI is set up for the second generation LT 1 that were produced from 1992-1997 is not a simple fix. The fuel injection and computer along with the cam will need replacing with either after market stand alone computer or go back to the carb and a single /dual plane intake with electrictronic/ Magneto ignition.
  11. #20
    Dec 2015
    Ron
    1968 Nova SS LT4
    This is an older thread but thought I would just mention I have done the 4/7 swap in my car. Custom ground cam from Elliot. I am running the Torqhead conversion so I just swapped the pins for the correct coils and injectors at the PCM. It was a really easy to do being I am using the LS1 computer system now. My machinists is an old Italian that always preached I had to do it to one of my motors as for the HP gains. Do I believe it makes that much difference, not really. I do feel that the motor is smoother Climbing to top end 6800 RPM's but I also have a balanced rotating assembly so I would expect it to be smooth. Does it sound different? I cant really tell since it was a complete new stroker build. I don't have numbers for the motor yet as I am trying to locate a dyno and tuner near me that has the time now to do it.
    Here is a photo of the motor.
