Page 7 of 7 FirstFirst ... 34567
Results 61 to 70 of 70
Thread: 97 Z Rebuild
  1. #61
    NICE MAN!!
    NICE!!!!!
  2. #62
    Thanks. Just have to figure out why It wants to idle really high when I drive it. When I first start it up it idles normally but when driving it idles really high like 3k sometimes. The throttle is kind of sticking so I'm going to ad a spring and see if that helps. Its like the tb sticks slightly open while running after it opens won't close all the way on it's own.
    Sent from my DROID X2 using Tapatalk 2
  3. #63
    May just be as simple as tuning your idle..
    when it sticks high.. are you able to manually drop it to close the TB... or is it closed and just "acts like that?"
  4. #64
    Yes I can close it manually and it idles normally again. Its like the spring on the tb doesn't have quite enough tension.
  5. #65
    Quote Originally Posted by Dhayes View Post
    I had the same issue on my as&m momoblade...the last tuner fixed it for me.... But i know fast bird had the same issue...does it feel like the piece on the side that the throttle cable attaches to spins on the shaft a lil?
    Or is it just binding on return?
    Larry (Popo8) Co-owner
    LTXtech.com
  6. #66
    Just catching on return right before closing completely. Not spining on the shaft at all.
  7. #67
    Shit...lub it the springs and the blades up and work it in and see if that helps....
    LTXtech.com
  8. #68
    I will have to try that tomorrow
  9. #69
    Feb 2011
    Clarksville, Tn.
    Nice job!! I remember when I got mine ready to fire up. It was 12:30a. With open headers, I drove it around the block at 1a. I have a sheriffs deputy that lives right across the street from me too. I know alot of my neighbors, & they knew it was coming. So it was ok. I did a small burn out in road the next day.
    1994 TA - MY toy!! CIA, EGR air pump & ac delete, LT headers, 52mm TB, P&P heads, CC305 cam, 1.5 RR, TRW 20 over forged pistons, spec 2 clutch,electric cut out, magnaflow exhaust, tune by Solomon.
    1996 Camaro RS (Y87)
  10. The Following User Says Thank You to Project96 For This Post:
  11. #70
    Fixed my throttle problem today. Added a couple return springs. Works fantastic now.
  12. The Following User Says Thank You to Dhayes For This Post:
