Results 11 to 20 of 34
10-27-2012, 07:31 PM #11"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
10-27-2012, 07:33 PM #12
it has white leather? the 30 on a grey seat is just to commemorate the 30th year, but its not a 30th special edition. and like fast bird said change out all the burned plug wires and rule that out.
1997 SS- 30th #80 SS #455 383, F1A, nitrous
http://www.gmhightechperformance.com...ler_ghtp_1203/
1995 Z28- 14:1, 355, Beer can on 4 wheels.
10-27-2012, 09:58 PM #13
Ahh I see. Well then its not a 30th Ann. Lol. I went ahead and started looking over the wiring harness and found some fun stuff. A few melted wires and connectors and random wires either ripped or cut. So I pulled the engine/trans harness out to the side to go through it. Alot of stuff was done halfa$$ on this I'm almost tempted to pull the motor tear it down and start over making sure stuff is right.
Sent from my DROID X2 using Tapatalk 2
10-27-2012, 09:59 PM #14"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
10-27-2012, 11:00 PM #15InActive Member
- Jan 2012
- 1997 z28 383 stroker
- oklahoma city,ok
- 2,859
If you end up needing a neutral balanced flywheel hit me up I have one for sale for $150 (it's a chromolly neutral balanced flywheel) I bought it brand new and ended up not needing it so its just sitting I've been trying to get rid of it for a while but everyone I talk to either end up just leaving me hanging or don't reply when I ask them if they still want it
You can't pee on what you can't touch (chevy)
10-28-2012, 02:52 AM #16
10-28-2012, 02:56 AM #17
Got the motor and trans out. Im glad I pulled it because half of everything I took off was loose... lol. Ill pull the heads tomorrow and see what's inside.did these come with aluminum heads or cast?
10-28-2012, 03:49 AM #18
Fbodies and vettes have aluminum heads, and i feel ya on the harness... My SS i bought it built and ive rewired the entire harness from front to back and replaced every moving part on the car because it was done half assed...
10-28-2012, 04:06 AM #19
Dang that sucks. Hopefully I can fix mine and I'd bot maybe I can find one at the junk yard.
10-28-2012, 06:51 PM #20
Well got the heads off and started looking around. Heads are 643's and Appear stock. Shortbock was recently done it still has pretty clean cylinders with cross hatching or whatever. Half the push rods are trick flow half are stock. Intake has a chunk missing next to a bolt hole. Opti was cracked. All but one header bolt was finger tight. Everything had just rtv poured on it.. going to pull the cam to see what that bad boy is next.
Might be switching around my game plan with this thing.
