Results 11 to 20 of 22
Thread: 52mm vs 58mm Throttle body.
10-23-2012, 09:17 AM #11
10-23-2012, 09:20 AM #12
The term "355" in this case means nothing. That's just the displacement, 5 cubes more than stock. The impact on the engine's ability to breathe more air and fuel is practically immeasurable with those extra 5 cubes over stock. The heads/cam (in this case, a 355) dictate how much airflow is required - NOT so much the displacement.
Now when you move into the larger CIDs like 383+ then it becomes a consideration but for all intents and purposes a 355 might as well be considered a stock bottom end.-Joe-
95 T/A.
Advanced Induction 383 - 10.81 @ 124.16, 1.43 60' Video of 10-second pass - 455whp/445wtq
10-23-2012, 09:45 AM #13
When the cubes are staying the same then RPM most importantly followed by VE will be the deciding factors on how much TB you need. Basically, a stock shortblock LT1 that's limited by the stock computer's RPM range will rarely if ever need larger then a 52mm...and even that is with a very stout H/C combo that can produce over 90% VE. Now, if your 355 is a nasty solid roller build spinning 8k then by all means go for the 58mm, it will make more power.
RPM is the most important factor for throttle body size. A high strung 7500+ RPM 355 will need a lot more TB then a street 383 spinning under 7k.93 Medium Patriot Red Z28: Forged 383,GTP'd AFR 220s(@227ccs), LE .7xx" Billet SR,1.7 Shaftmounts,24x,Maxed Supervic,4150 TB. :12 Metallic Spark Black ZX14R: 1.5" drop, GP slipons, -2 Vortex rear. 152mph trap SWB, stock motor...now with Nitrous... :09 Victory Red LS3 Z51 Vette: Blackouts, muffler delete, sub. Purchased bone stock w/18k mi.
10-24-2012, 12:43 AM #14
10-24-2012, 01:08 AM #15
if you run a 58 remember your intake opening is only 54mm... i run a holley 58mm on my SS (383 boosted) and i run a 54MM AS&M on the 355 in my Z28
1997 SS- 30th #80 SS #455 383, F1A, nitrous
http://www.gmhightechperformance.com...ler_ghtp_1203/
1995 Z28- 14:1, 355, Beer can on 4 wheels.
02-20-2014, 07:09 PM #16Lurker
- Feb 2014
- Casey
- 1996 Camaro SS
- Illinois
- 23
Just bringing an old thread up after doing some searching. Do you guys thinks a ported 52mm stock throttle body would be enough for my setup when it's done? (See sig)
I feel like I should make a step up over the stock TB since I will be running the LE ported intake.
After reading about the split blm and IAC problems with the 58mm TB's it kinds of sounds like something I don't really feel like fixing to make the car run right. Opinions?
1996 Camaro SS #308, M6, (4.10 on the way), OBD-I Conv, OBX 1-7/8" Stainless Headers, Custom 3" Stainless Y Pipe, 2OTL
355-Stock Crank, 6" Forged Rods, Forged Pistons-11.5:1 SCR
LE2 Heads, LE2 Ported Intake, LE/Lunati 231/239 110 LSA Cam, Tune In Progress
02-20-2014, 07:14 PM #17Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
02-20-2014, 07:31 PM #18Lurker
- Feb 2014
- Casey
- 1996 Camaro SS
- Illinois
- 23
Cool thanks for the reply. I figure it's worth stepping up to a larger size with the 52mm. I'm trying to maintain as much reliability and drivability when I build my car as I can so the bored stocker is appealing to me. It's amazing how many threads are on all the different boards about TB's. It all seems to come down to some guy maybe making a few extra HP with a 58mm over a 52mm.
02-20-2014, 08:12 PM #19Xtreme Member
- 7,269
Supporting Memberyes, dont buy into the 58mm witchcraft. we are still paying the price for putting the 58mm tpis throttle body on our stock bottom end LE2 build. after all the headaches it wasnt worth it.
02-20-2014, 11:44 PM #20Lurker
- Nov 2013
- David
- 97 355 Green TA
- Deltona, FL
- 303
I've seen some instances where the aftermarkets just don't measure up to a stocker bored out. There was a thread on this forum comparing the IAC's and that really convinced me that I'd stick with a stock TB.
IMHO if you're not a 383 don't even consider the 58mm. 52mm will feed you just fine up to 500hp which without power-adders is hard to come by. Go on Ebay and you'll find some remanufactured 52mm stock TB's for a decent price.97 TA (Rebuilding):Stock bottom end 355, CAI, 52 TB, Ported intake and lt1 heads, 227/235 LE cam, Ultra-Pro-Mags 1.6RR's, Hooker LT's, single flowmaster, McLeod Clutch. Need a 9inch rear to handle the abuse
FLOGROWN
