KeeAudio
Results 1 to 7 of 7
    Default 2.02/1.60 valves in stock lt1 heads
    does anyone know what seats are needed to put 2.02/1.60s in the lt1 heads?
    Jun 2011
    rapid city SD
    Not sure mine came like that when I got my new engine
    Oct 2008
    las vegas
    You need a butt load of pocket portwork done to unshroud it for 2.02 1.60.... you would be looking at LE3 heads at that point...
    10 Second N/A Club
    Josh
    96 Z28
    Holden, MO (KC)
    FWIW I asked about upgrading my LE2's with the bigger valves and LE told me the gain in performance wasn't worth the labor needed to put that size valve in a stock head (aprox. 10 hp for a 400+ rwhp car). Sorry I know that doesn't answer your question.
    -Josh
    co-owner of BDBRacing.com
    NMCA OC 9004
    10.68 @ 129 1.57 60'........still workin on that 60' shootin for 1.4's!
    Yea there is 9 second cars with the 2.00" valves in ported stock heads which takes no seat replacement. If your goal is bigger than that you may be better off with aftermarket heads. I too am sorry about no legit answer, just legit info.
    '94 Formula m6: AI 200cc h/c - MWC - Moser 12bolt
    Feb 2010
    NC
    got mine on the stock seats
    The FABRICATOR!
    Jul 2011
    southern illinois
    2.02/1.60 on stock seats? if the machine shop didn't open them up for the larger valves, you're not getting the full benefit of larger valves. If he did then he cut through the hardened surface of the seats. If this is the case, the longevity of the seats has been greatly diminished.
    Again, not helpful to the OP. Sorry.
