Page 87 of 116 FirstFirst ... 377783848586878889909197 ... LastLast
Results 861 to 870 of 1156
  1. #861
    https://www.summitracing.com/parts/sum-g7600
    Not sure if that extended/compressed length works
  2. #862
    pshhht
  3. #863
  4. The Following User Says Thank You to shownomercy For This Post:
  5. #864
    So its almost spring time, and still own this silly car
    Added some blue LED to the cluster for some lulz, and cut out the LEDs for misc crap I don't have anymore
    This poor example of a radiator is from 1995
    So new rad, new hoses and new cap later...
    Ordered a few pieces of pipe to redo this crossover, manholes and turbo kits are not good friends
    Hoping to have the turbo tuck up higher than before and pull the front crossover up higher. Don't buy a kit made for a sway bar and AC if you have neither is the lesson here.
  6. #865
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Uhh.....dayum!!!
  7. #866
    And, no going back
    Semi success, ran out of gas after tacking it all up
  8. #867
    And another update to confirm the car still exists. Yes, I have ADD when it comes to car stuff and or most things that I can tinker with.
    Tailpipes!
    Cutout, part duex will have the boost ref gizmo here
    Pink Pan, and slightly better ground clearance on the cutout area, hopefully
    Vclamp all teh thingz!
    Custom zip tie exhaust holder #Semaready
  9. #868
    Downside to running a catback is all the stuff I half assed on, is now in the way of OEM stuff
    Thankfully, DEI makes cool heat shields
  10. The Following User Says Thank You to shownomercy For This Post:
  11. #869
    Glad to c ur back at it
    LTXtech.com is my drug...
  12. #870
    It comes in waves, and I got the bug to tinker with it. So with the help of some good friends, cleaning up the half ass rush of the original build years back.
    Spent a solid three hours in the car tuning yesterday with a friend. Cleaned a lot of part throttle stuff up and made the car overall much nicer to drive.
