Results 1 to 6 of 6
Thread: Need help quick with lt1 noise
07-17-2011, 04:45 AM #1
has a noise when you left off and noise holds steady around 2500 rpm sounds like something up top my not exactly sure.,
i have readjusted the rockers twice and it still does it idk whats wrong with it.
i neeed to figure this out i start my new job on tuesday need help fast!!!!!
thanksDustin Dillow-Tuned by Dillow's Tuning Solutions
95 Firebird Formula Cam, Bolt Ons, QP 9 Inch 3.50 Gear, Full UMI Rear Suspension, 3700lbs
7.86 at 86.20 mph 1.67 60ft, 7.16 at 99 mph 1.51 60 ft on .063 jet NX Shark Nozzle Single Fogger
07-17-2011, 06:51 AM #2
07-17-2011, 01:09 PM #3
Nope stock everything
07-23-2011, 09:31 AM #4The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
rod bearing
Not to scare the crap out of you but I have had a spun rod bearing make that sound before. It would tap at idle, clear up under light throttle around 1k, and come back around 2500. It was especially noticable when I let off the gas. Sometimes it's hard to tell if a sound is coming from top or bottom because of how low our cars sit. Try using a wooden dowel or plastic handled screwdriver to listen around and see if you can pinpoint it.
07-23-2011, 10:12 AM #5Founding Member
- Jay
- 93 Ultra Z
- Delaware
- 3,144
I had a similar issue. It was either the bad bearing for the water pump drive, the cracked windage tray, or one of the rod/main bearings I replaced. I ended up pulling the motor and tearing it down. Noise is gone now.
07-23-2011, 10:10 PM #6"The Rock"
Hows your oil pressure.... cold and hot?
