Results 11 to 20 of 36
  1. #11
    9.826 @ 132.02--1.3x 60'--200 Nitrous Outlet Spray Bars--Ray@NitroDaves--94 Formula--700r4--28x10-15 Hoosier--#12--HR 396cid
    off the throttle around the 1000' mark....new solid roller combo testing this spring
    http://ltxtech.com/forums/image.php?type=sigpic&userid=241&dateline=12653889  02
  2. #12
    Feb 2013
    1997 Camaro Z28 30th anniversary
    Edison, NJ
    11.07 @ 128. 1.51 60ft Stock short block ported heads, custom cam, hidden nitrous kit 125 shot, m6, 28.5x 13.5 Hoosier Qtp . This was back in 2001
    Cliff
  3. #13
    Updated...if you dont see yours please resubmit with the correct format
    1. 8.68@153.51--1.28 60'--350 Nitrous Oultet DP-- Tony Shepherd--93 Z28--PG--29.5x10.5x15--post# 2--396 ci
    2. 9.826 @ 132.02--1.3x 60'--200 Nitrous Outlet Spray Bars--Ray@NitroDaves--94 Formula--700r4--28x10-15 Hoosier--#12--HR 396cid
    3. 10.07@135 1.47 60ft.... NASA --396, 200 shot, th350, 3500 race weight.
    4. 10.35@135.20--1.52 60'--200 Nitrous Outlet DP-- Formula383--95 Formula--M6--28X10.50x15--28X10.50x15--#4-- 383
    5. 11.07 @ 128. 1.51 60ft --Cliff30thz--Stock short block ported heads, custom cam, hidden nitrous kit 125 shot, m6, 28.5x 13.5 Hoosier Qtp . This was back in 2001
    6. 11.2 @ 118.xx 1.8x 60ft. AChotrod 96 Formula WS6, 150 shot, LE2, th350, 275/60-15 MT DRs. Run Started bad and ended worse
    7. 11.33 @ 118---1.66---315BfgDr---NX150 shark nozzle---96lt1m6---Z28---M6---stock bolt on Lt1
    8. 11.43@118--1.66 60'--150 TNT Plate--green96ta--96 Trans AM--4l60e--275/40/17 NT555r's--#1--Stock Short block
    9. 11.53 @ 114--1.60 60'--125 Dry shot--79LT1Monte--1979 Monte Carlo 4L60E--255-70-15--#7--383 ci
    10. 11.58 @ 121--1.74 60'--175 shot--gregrob--94 Z28 M6--26 x 11.50 x 16 MT ET Street--#6--Cam only 350
    11. 11.60 @ 118--1.56 60'--150 shot--SexyTransAm--95 T/A--A4--26 x 11.50 x 15 MT ET Street--#6--Cam only 350
  4. #14
    Aug 2010
    Mount Sterling, KY
    9.91@135--1.38 60'--200 Shot Nitrous Outlet Single Fogger--1994Z28--1996 Impala SS--TH400--Mickey Thompson Drag Radial Pro--383
    1996 Impala SS - 6.28@110/9.91@135
    2010 LTx Shootout Extreme Street N/A Runner-Up
    2012 LTx Shootout Extreme Street P/A Champion/Record Holder - 10.09@135
    2013 LTx Shootout Modified P/A Runner-Up
  5. #15
    Aug 2012
    1968 SS Camaro 396LT1
    NW AR
    8.930@150.63 1.278 60' 41n/31f 100 shot NX plate Noice 68 Camaro powerglide Goodyear 33x16-15 396
    68 Mechanical Alcohol Injected LT1.
  6. #16
    Mar 2010
    Sean Foster
    1995 Trans Am
    Barboursville WV
    9.91--1.39--200--1SICKTA--95 TA--4L80E--275 Pro--post#23--383ci
    Sean Foster
  7. #17
    Aug 2009
    Kyle
    '95 Trans Am
    Elizabethtown, Kentucky
    11.35 @ 120 same set up better tunning
    Sent from my SAMSUNG-SGH-I547 using Tapatalk
    Kyle
  8. #18
    Apr 2012
    Cameron
    Dover, De
    Got bored...Updated/Added/Fixed format
    1.8.50 @ 158mph--1.227 60'--300 NX 2 Stage plate--SSmitty--94 Caprice--PG--33x16.5x15--#29--410
    2. 8.68 @ 153.51--1.28 60'--350 Nitrous Oultet DP--Tony Shepherd--93 Z28--PG--29.5x10.5x15--post# 2--396 ci
    3. 8.69 @ 155.24-- 1.229 60' --150 shot NX plate--Noice--68 Camaro—powerglide-- Goodyear 33x16-15-- 396
    4. 9.826 @ 132.02--1.3x 60'--200 Nitrous Outlet Spray Bars--Ray@NitroDaves--94 Formula--700r4--28x10-15 Hoosier--#12--HR 396cid
    5. 9.91 @ 135--1.38 60'--200 Shot Nitrous Outlet Single Fogger--1994Z28--1996 Impala SS--TH400--Mickey Thompson Drag Radial Pro--383
    6. 9.91--1.39 60’—200 shot --1SICKTA--95 T/A--4L80E--275 Pro--#23--383ci
    7. 10.07 @ 135 1.47 60ft.-- 200 shot--NASA--th350--#12--396. 3500 race weight.
    8. 10.35 @ 135.2--1.52 60'--200 Nitrous Outlet DP--Formula383--95 Formula--M6--28X10.50x15--28X10.50x15--#4--383
    9. 10.46 @ 131--1.48 60’ --200 shot—Chased--4l60--#8--H/C/I 355 12 bolt
    10. 11.07 @ 128--1.51 60’--Hidden nitrous kit 125 shot--Cliff30thz--97 Z28-- M6--28.5x 13.5 Hoosier Qtp --#14--H/C LT1,
    11. 11.2 @ 118.xx --1.8x 60’--150 shot --AChotrod-- 96 Formula WS6 --th350-- 275/60-15 MT DRs--#10-- LE2. Run Started bad and ended worse
    12. 11.33 @ 118--1.66 60’--NX150 shark nozzle---96lt1m6---Z28---M6--315BfgDr--#11--stock bolt on LT1
    13. 11.35 @ 120--1.56 60'--150 shot--SexyTransAm--95 T/A--A4--26 x 11.50 x 15 MT ET Street--#6--Cam only 350
    14. 11.43 @ 118--1.66 60'--150 TNT Plate--Green96ta--96 Trans AM--4l60e--275/40/17 NT555r's--#1--Stock Short block
    15. 11.53 @ 114--1.60 60'--125 Dry shot--79LT1Monte--1979 Monte Carlo 4L60E--255-70-15--#7--383 ci
    16. 11.58 @ 121--1.74 60'--175 shot--Gregrob--94 Z28 M6--26 x 11.50 x 16 MT ET Street--#6--Cam only 350
    17. 11.90 @ 113.73--1.686--150 nozzle --Zooguy--94 formula--4l60e--M/T ETstreet(bias) 28x12.50/ 15--31#-- 350 stock longblock
    Formula Build Thread
  9. #19
    Aug 2012
    NW AR
    Default LTXTech Nitrous fast list
    60ft 1.229
    1/8 5.53 @ 125.95
    1/4 8.69 @ 155.24
    150 shot i forget the correct jetting, it was something i brewed up.
  10. #20
    Ticket booth was down at Z Max dragway so I had to get printout from tower.
    1994 Caprice 410 Stock Block LT1
    8.50 @ 158mph http://youtu.be/_wodvN6bCMY
