Results 1 to 10 of 12
10-18-2008, 01:47 AM #1
Anyone have pics of hammered well area to fit big tires?
just wondering before I start smacking my mint car!
Will 1/2" spacers put me away from rubbing with a 325/50 on a 15x10 with 7.5 backspacing?95 Z28 FORGED 355, JE 8.5:1 PISTONS, 230/239 - .530"/.546", 114 @ 110 CAM, stock heads, Pacesetter longtubes, 10 PSI from ATI P-1SC Procharger, 60#, 4L60E, Yank3600, 9" 3.73, ET Street 28x12.5x15, 3450lb
10-23-2008, 04:40 PM #2
Just start wacking away then some touch up and your good.
10-27-2008, 03:20 PM #3
I've got some pics. I'll try to post them up.
1995 Z28 - disfunctional now, perhaps insane after its "treatment"
10-27-2008, 03:22 PM #4
Here they are;
10-27-2008, 03:23 PM #5
Is it just the lower front of the rear wheel wells that need it? I have 315/35/17 nittos and they dont rub at all and seems there is still some more space. Plenty of room every where but that front lower lip.
10-27-2008, 03:38 PM #6
Well first off, you have 17's. 18's would be more prone to rubbing. 2nd, not all tires are the same width per given sizes (meaning a 315 Nitto is not the same width as a 315 BFG).
Nittos are more narrow than most other tires given the same size parameters. Some might not rub with nittos but then rub with MT DR's. The circled areas in the above pic are the areas that will rub first. Keep in mind that even though they might look like they have room and don't rub while sitting there, under acceleration in your car is when if they are going to rub, they will. I reccomend taking the car out after you think you are good, and driving it, and checking the inside of the tires. If good, take it out and open it up a bit. Then check again. If your tires are indeed contacting the inner wheel well, its not going to take much to eat into the tires and make them un-safe.1995 Z28 - disfunctional now, perhaps insane after its "treatment"
10-27-2008, 04:24 PM #7
I have heard nittos are skinnier than MT or BFGs but wasnt sure if thats true or not since I never measured them. That would make sense though.
I was worried about it rubbing but couldnt hear/feel anything while testing it out and after the track took them off and checked all over for any signs of rubbing and found nothing.
Thanks for the pics I now know where I have to BFH next season.
10-27-2008, 07:53 PM #8
CALL911 -thanks - that's exactly what I wanted to see
10-27-2008, 07:58 PM #9
No problem
10-27-2008, 08:20 PM #1095 Z28 FORGED 355, JE 8.5:1 PISTONS, 230/239 - .530"/.546", 114 @ 110 CAM, stock heads, Pacesetter longtubes, 10 PSI from ATI P-1SC Procharger, 60#, 4L60E, Yank3600, 9" 3.73, ET Street 28x12.5x15, 3450lb
