Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Mar 2014
    Eric
    1997 Trans Am WS6 - H/C/I/E, Full BMR, 383, M6
    Cheyenne Wy
    Sorry to bring this back, during a trip to the local junkyard I found a abundance of late 4th gens.
    Would I be able to do the caliper swap and still run lt1 disks in the front? When I purchased my car it had drilled and slotted rotors all the way around.
    Sent from my SPH-M840 using Tapatalk
    New build coming soon.
  2. #32
    Mar 2009
    Spring, TX
    No, LS1 rotors are physically larger. That's the whole advantage of going to LS1 brakes, because of the bigger rotors and calipers.
  3. The Following User Says Thank You to Spartan7 For This Post:
  4. #33
    Sep 2014
    blake morder
    1994 camaro z28
    I'm going to drag this up again, what brake lines should I use? The ls1 and lt1 lines are both too short. I've had the lt1 lines on and theyve stretched pretty dangerously.
  5. #34
    Jul 2013
    95 Firehawk
    Indiana
    OK. I am getting ready to do this upgrade. Did a google search, and found that C4 brake lines are longer and should fix the bent line option. Ordered a set of braided lines. Will update with the results.
  6. #35
    Cameron
    Dover, De
    Quote Originally Posted by tazman71 View Post
    C4 or C5...I run C5 braided on mine and are perfect.
    Formula Build Thread
  7. #36
    Aug 2009
    Kyle
    '95 Trans Am
    Elizabethtown, Kentucky
    i bent and zip tied my stock lines and they work
    Kyle
    just ur everyday slow LT1. wanna try her out?
  8. #37
    Jul 2013
    95 Firehawk
    Indiana
    You are correct, C5. They fit perfect.
