Mickelson-Horizontal
Results 1 to 8 of 8
    Jun 2010
    WARRENTON, VA
    Default 9 inch aluminum center section
    Buying a Midwest Chassis rear and Eric mentioned a Yukon gear thrubolt centersection as a less expensive option to the strange and moser units. Just wondering if anybody has experience with this unit. Eric did say they haven't used them much and it is a newer product. I don't mind spending the extra money for the others but if the yukon will do the job, i'll spend the money on something else. The power goals are eventual 700-800hp with nitrous on a nitrous/auto car. Maybe a transbrake later.
    96 impala ss 9700 miles 7.72 @ 91 on 100 shot 1.65 60ft 94 T/A under construction 04 s281 saleen 07 suburban 6.0l
    09 chevy cclb 8.34@81 w/tool box and ladder rack
    Big Papi
    2015 Fusion Titanium AWD
    Moscow Mills Mo
    Blog Entries
    1
    http://stores.ebay.com/Tripp-Motorsp...34Q2ec0Q2em322
    Who I got my center section through.
    Im running
    3.82 Gears
    Nodular Housing
    Detriot Locket
    1350 Yoke
    Drilled for a oil pump
    Daytona Support
    Lightened Housing
    All Rem Polished
    For 800 Shipped. You cant pass that up. Right now they have one in 5.8x gear Id give them a call I am very happy
    I also have my Ford TracLok from my old thirdmember if you are interested shoot me a pm. Its all boxed and ready to ship to someone
    Jun 2010
    WARRENTON, VA
    I was leaning towards alum to save weight. The cost for the yukon alum upgrade is $285. over nodular. I'm buying everything in a package deal w/spool and 3.89's. If the timing works out i may be interested in the susp.pieces in a few months if you still have. just a question, do you think there would be much interest here in my nib gears set 3.73 w/install kit / girdle and fluid. that will give me a little extra cash sooner.
    Big Papi
    Moscow Mills Mo
    Blog Entries
    1
    Dont get aluminum you dont need it. And yes someone should eat up that gear kit. have you ever driven a spooled car? How much driving are you planning on doing?
    Jun 2010
    WARRENTON, VA
    weekend cruise or to track. the only concern i have with the spool is if i want to park in a parking lot. with my eventual power goals my only other consideration would be the wave trac. but thats a big price tag. I plan to be 500-550hp on spray in the spring and 750-800 in 2012
    8 Second Club
    Camanche Iowa
    The yukon gear isn't bad. I didn't know they had an aluminum center section. Unless that is the strange or moser center with a yukon gear.
    My rear end doesn't have much on it mileage wise. But it is a yukon gear that I set up and I have no complaints. Been in the car two years.
    So far 10.576 @ 128.64 on a 1.563 short time. N/A.
    8.957 @ 151.60 on a 1.349 60' time
    THE FIRST 8 SECOND NITROUS POWERED LT1
    Jun 2010
    WARRENTON, VA
    Eric said the center section was a newer product and they hadn't had a chance to personally test it but had used for a couple customer cars. the strange and moser are $215-300 more than yukon thru midwest. I have yukon 3.73 r&p in my impala and they are great, no noise and seem strong. I am always leary about buying something when it is first out. That's why I wanted to put this out there.
    Jun 2010
    WARRENTON, VA
    Jakesz28 do you have midwest lca &panhard, drag bar. I started a thread wanting to check if anyone had the full rear setup from midwest. If so, how do you like it. This is the route I would like to go, get it from the same place.
