Results 1 to 10 of 34
Thread: Limits of a single pump
10-08-2008, 07:27 AM #1Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
So when I figure out my fueling situation I need to know if i NEED to go to dual pumps or not
What is the largest (highest) flowing single pump I can fit comfortably in our tank and the limits of it?
This will be for a turbo 355 74mm turbo ranging from 5-15psi.. I don't expect to make anymore than 650whp more realistically 600whp
10-08-2008, 07:55 AM #2
I believe the walbros are rated at 550hp...not sure if thats rwhp or flywheel. Either way you'll probably benefit from duel pumps. I will be adding another pump to my tank a little later this year.
There is a great write up on LS1tech that mightymouse did.
Are you thinking about putting it together yourself or buying a Nasty setup?
7.10ET 88mph 1/8th (old setup)
10-08-2008, 08:32 AM #3Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
Just an FYI, but the Corvette Guys are making in the 650-700 range on a single and 60# injectors with a Whalbro 255LPH and a Boost-a-pump. Granted, that's at 58 PSI though. On our 43.5 PSI system, I don't think I'd try to push it past about 550 or so, even with a BaP.
Here's a read for you though, food for thought if you can find one: http://forums.corvetteforum.com/show...em+fuel+return
10-08-2008, 08:58 AM #4Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
10-08-2008, 09:05 AM #5Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
Nasty does. I was talking with him about it but didn't like how pricey he was. $225 for welded rails alone wasn't very attractive to me, hence my rails which I have nowhere NEAR that in.
wow that's crazy... how much work would it take to fit one of those pumps correctly in an fbody
10-08-2008, 10:03 AM #6Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
So I would probably need either two supra pumps or one of those modded pumps?
10-08-2008, 10:13 AM #7Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
10-08-2008, 10:14 AM #8
A fuel system is never anything I look to put together "cheaply".
For a single pump setup to support high HP levels I would look into converting to an Aeromotive A1000. A little more pricey but would easily support your power goals now and in the future.1994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
10-08-2008, 10:17 AM #9Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
Since that's an external, would he be looking at baffling the tank and a complete -an setup at that point also though? I'm not questioning the A1000, at all, but moreso the cost involved. You can do the same as the A1000 for 85% of the higher HP cars out there with the twins in-tank.
10-08-2008, 10:37 AM #10Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
I'm not trying to be cheap or anything but my funds are limited... this is not an all out bad ass build as it will still have stock heads and intake...
This is going to be a DD as it always has been and will regularly see trips from NY-FL and and back
I know that I will not have the money for a full conversion like that and I wont have the time either.
What is a basic double pumper setup to handle say.. 750whp to give myself some room. What all will need to be done?
