Cable routing for battery relocation.
Hi all. I'm hoping to finally bring the battery relocation further up the project list for this year.
When I bought the car I removed and replaced the carpet the following day. While I had the carpet out I laid in a length of zero gauge wire in anticipation of eventually moving the battery.
While pondering where I might go through the fire wall I found an easy way through in behind the glove box.
My concern is that the cable runs straight beneath the PCM and may produce EMI?
is this likely to cause a problem and if so, would wrapping the cable in one of those EMI suppressing wraps be enough or should I find a better way to run the cable?
Thanks,
Jon
