.https://uploads.tapatalk-cdn.com/201...31621b3e10.jpghttps://uploads.tapatalk-cdn.com/201...098d2832f9.jpg
Might want to check in on this thread.
http://www.impalassforum.com/vBullet...l-spacers.html
I don't know how far you want to go with this, but if you're not keeping ABS, this is the best way to use 5x4-3/4 pattern and a much larger choice of wheels.
Custom order the Moser axles for the impala with the smaller pattern ($240), then buy front rotors for a 92 Camaro B4C, Exact same rotor minus the reluctor,
Thats prob a little 2 involved for now. If the car ever needs a stronger rear due to the camaro motor... ill make those adjustments then... but for now, it will just be adapters.
Also... abs ring broke when we did gears... so no more abs. Lol.
Thanku tho...
